1974 duster dash cluster problem
QuintinMotorCompany
Georgia Vermont
Hi,I just finished a int. project on my 1974 duster. I took the cluster out for a while and then I put it back in. The SAME way i took it out. for sure! I labled everything. I put it back in and the only thing that works is the amp meter and speedometer . I know the amp gauge works because it has power to it. and the speedo is mech. everything else has the circuit board. is it possible for these to go bad? where can I get a new one? is the whole cluster junk? Thanks in advance for all help. :burnout::D
Yes you can get a new circuit board. I had to get one for my 73 Scamp...Its real easy...I got mine from Classic Industries. I got new gauges there also..
If it is a metal housing it requires a chassis ground. Limter, lighting, etc., wont work while dangling from the connectors unless you add a ground wire.
