AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,608
- Reaction score
- 13,844
The 1406 should be set up for the 16"vacuum that your engine is making.
But to answer your question, yes. But to expand on this it is easy to prove. With the engine running, loosen one M-rod cover and turn it far enough to the side so that you can see the piston down there. Cover the screw so it can't fall out, and have a helper put the tranny in gear.The piston should stay down during the engagement.
Now, getting back to the real issue. What causes the engine to stall? This is usually a sign of a bad T-port sync,which is often caused by late ignition timing,but not always.
If the throttle is too far open, in an attempt to get enough fuel into the engine to cover a vacuum leak, that is another cause.
If the idle speed is set too high,in an attempt to make the engine idle smoother, possibly in response to insufficient timing, that is another.
If the TC is too tight, and putting it in gear drags the idle-speed down too fast and too low,that is another.
But the principle and common denominator is that the engine is stalling due to either A)flooding because the metering rod pistons popped up, or B) airspeed through the venturies dropped too far,too fast to sustain fuel flow from the low-speed circuit.
Remember that the low-speed circuit is actually the Transfer system, augmented at idle, by the mixture screws, and modified by the fuel level.This is why it is so important to get the fuel level exactly right and the T-ports synced.
The T-port sync will demand an idle timing, to get the idle speed up/down to where it needs to be. I am one of the few guys here,that does not set the idle timing to satisfy the highest vacuum philosophy. I set the idle timing to what the engine tells me it wants,not to what I think it might need.You can,or may get to the same end point following either philosophy.But the T-port sync may be correct over just a very small range, so it has to be set first, in my opinion.
