1974 Valiant Slant Six to V8 Motor Mount Question
66340SEDAN
FABO Member #3649
Minnesota
1974 Valiant /6 to V8, are the K-frames different between the two? Do they use spool type mounts, could I just get V8 mounts and use the stock /6 K? Thanks!
They're not the same. Either get conversion mounts from Schumacher or swap a V8 K member for your swap.
i just bought a '74 v8 car for that very reason, that and the discs, bigger rear end and bigger bolt pattern. 250.00 and i was able to drive it home..barely
I also used this conversion part for my Dart and it worked well ...
