MoparTrucker
Active Member
So I have a 1983 dodge W150 with the 318 engine all stock, just recently got it as a starter project truck. Pretty new to mechanical work and will need some help. So the problem is it stalls and dies, I turn the key and start it turns over, and will run as long as I keep the key held down. As soon as I let off the key it stops, I was thinking at first fuel? Replaced fuel filter and broken fuel hoses didn't do anything. So my thoughts were then the ignition coil, but I tested it and has right OHMS. Gonna put new spark plugs and wires in to see if that does anything, needs a tune up anyway. Any thoughts?
