1990 318 rocker arms
coyote42
West Seneca, NY
Hi all, I am re assembling a 1990 roller cam 318 from a truck. It is for my 70 Duster. When I took it apart I found some shaft mount rockers replaced. What I have now is some rocker arms have a offset hole in the pivot point of the pushrod and some do not. All pushrods are hollow. What is the correct rocker arm for this engine? I assume the hole is for extra oiling.
Also, how much preload should roller hydraulic lifters have with the pushrod from factory?
Thanks
Rollers oil the pushrods thru the lifters....older engines oil thru an oil passage that runs thru the block, head's and rocker shafts
I understand that for Magnum engines but this is a roller LA 318. It does oil through the head and rocker shafts but also has some rockers with the hole. I think someone added them because it looked random.
Here is one of each that was in my motor. Some with and without holes.
91 318 Roller Engine
No holes in the rockers:
Earlier LA small block has the oil holes in the rockers:
Kind of noticed the roller engine pushrods chewed a little more than the LA engines. May have heavier valve springs to offset the extra mass of the roller lifters so they chew a little more.
Maybe the OP's roller engine had a few rockers that were chewed bad enough to replace them with the earlier holed rockers he had on the shelf from the LAs.
Think it would be a good idea for the OP to check all of his '90 pushrods to make sure they are all hollow, and not a few of them solid to go with the oil holed replacement rockers.
I have heard it said that oil holed rockers on the hollow pushrod tube roller engine can drop the oil pressure some cause it is not capped off to hold pressure. Just a thought.
LAs are not sending oil up the pushrod tubes cause they are solid.
Thanks
Let me know if need some rockers for your roller motor.
All pushrods are factory and hollow. I had another 90 318 with hollow pushrods before. Just haven’t seen the rockers with holes in the cups. Have the original 318 for the Duster and rockers do not have holes.
on the roller motor with shaft oilomg to the shaft and pudhrod oil to the cups -the holes are noy necessary but they don't hurt
They dont need them or use them on the la roller motors. No holes in rocker push rod cup,just the push rods.
