PanGasket
has cork sides
this won't hurt anything? I am gonna give you a call today Terry
Are you changing out the cam and lifters?.....got the intake off or not?
Work it back and forth, I bet it's just oil schmutz buildup on the schaft.
managed to get it up an inch and a half and disengaged. now it won't come up anymore! figures...
If it clears the cam, you don't HAVE to take it all of the way out. It would be nice to clean the crap off of it though. I bet your engine has a lot of sludge in it.
When you remove the cam, make sure you do it carefully, the cam bearings are easy to mark up and the lobes are sharp. Use a long bolt that screws in the end of the cam to use as a handle works good here.
I would suggest you get a FSM or any book with pictures of how to do a cam change on a small block mopar for when you put it back together, or you will be inventing new swear words if you put it back together wrong.
You're doing good so far, it's a lot of work to do this right. :cheers:
