2000 durango rear in early a-body
Transmission and Drivetrain Tech
  1. pettybludart
    pettybludart Well-Known Member
    15,721
    120
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    8:56 AM
    Will a 2000 Durango rear fit early A-body??Any suggestions would be appreaciated.Thanks
  2. grumpuscreature
    grumpuscreature Resident Curmudgeon
    3,016
    37
    Mar 11, 2006
    inabox
    Local Time:
    9:56 AM
    You may be better off looking for a Jeep rear end. The Durango rear may have 6 lugs. I know the one in my '99 Dakota did. Other than that, it is just a matter of welding the spring perches in the right place and bolting it in. It will be a little wider than stock but not that bad.
  3. RedFish
    RedFish Well-Known Member
    24,040
    2700
    Sep 5, 2007
    Local Time:
    8:56 AM
    I've heard the 8&1/4 rear from under the uglier square box Cherokee is usable too.
  4. OldVart
    OldVart Well-Known Member
    5,430
    9
    May 24, 2005
    Forestburg, Alberta, C eh n eh d eh
    Local Time:
    7:56 AM
    Hey Red, watch it. You're going to give my 3 Cherokees a complex. Uglier indeed!! :)
  5. moparsegura
    moparsegura moparmaster
    970
    5
    Mar 26, 2008
    Local Time:
    8:56 AM
    ok, nobody slap me, but i helped a buddy of mine put a ford explorer rear with factory disc-brakes under a 72 Dart. I tried to talk him out of it, but when it's all you got what can ya do? any way, it fit pretty good. and stops to!!
    p.s. it also had the 4.5 b.p. so you can run a mopar wheel
  6. pettybludart
    15,721
    120
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    8:56 AM
    Thanks For The Help Guys!!and Have A Happy Turkey Day !!!
  7. oldmoparsrule
    oldmoparsrule Well-Known Member
    458
    2
    Mar 19, 2006
    Pasadena, CA
    Local Time:
    6:56 AM
    yea, I have looked into this...
    -Ford 8.8" rear axle from a 1995-2001 Ford Explorer is 59.5" wide (between wheel mounting surfaces). Most came with 3.55, 3.73 or 4.10 from the factory. The bolt pattern is 5x4.5.
    -65 to 72 A bodies are 55.6 from wheel mount surface to wheel mount surface.
    The explorer pinion is offset to the left side by 2.25. This means that you could cut 2.25 off of the right side and then use a factory replacement axle left side axle to get an overall width of 57.25 WMS to WMS. If A-Body width is 55.6, then you are still very close, with very little work.
    You would still need to do the following:
    -Shorten the housing
    -Cut and re-weld the spring perches
    -(Maybe) cut and re-weld the shock mounts.
    -Get a replacement short side axle
    -(Maybe) Get new rims with appropriate offset to accommodate 1.125" wider axle per side.
    All in all, you are looking at paying a competent welder to do part of this...and you are purchasing a new axle shaft. I would imagine with good "pick-a-part" skills you could do this very cheap ~$200 to $400 max (+ new rims). My Jeep buddies do this conversion all the time, and they stand up to 35+ inch tires with ARB lockers and HUGE torque.
    Compare this with the following (Purely estimates, YMMV):
    At the spring fling a few weeks ago, I bought a 489 case with 3.23 gears (peg leg) for $80. A guy from this group will ship you an A-body width 8 3/4 for $250 to $300. A set of factory A body 8 3/4 axle shafts can be had for between $100 and $200. Depending on the bolt pattern, brakes would be another $100 or so. So, you could have an A body 8 3/4 for about $600 (VERY cheap, I know). Then a sure grip unit would be another $450...so you are over $1000 for the 8 3/4.
    Again, YMMV (Your Mileage May Very).
    If you go this route, take lots of pictures, and write it all up.
    Sounds like it could be an alternative for folks who do not need the ultimate strength of the 8 3/4.
    Thank You!
    OldMoparsRule!
  8. RedFish
    24,040
    2700
    Sep 5, 2007
    Local Time:
    8:56 AM
    LOL You'll have to admit the earlier ones wern't so attractive. Utility vehicles weren't supposed to be.
    I live in Cherokee country. No tasteless, rude indian jokes from me today.
    Cheers
    Great info here concerning Ferd Exploder rears :)
    Thanks again
  9. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,136
    2811
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:56 AM
    Our '07 Liberty has factory rear disc brakes. Wondering if such a rear end would be a good candidate for an A Body swap. I'm sure perches would have to be moved to the appropriate location and total width checked. Seems at first glance it might be doable.
  10. fishy68
    fishy68 Tyr Fryr's Inc. FABO Gold Member
    16,943
    922
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    8:56 AM
    A-bodies have the pinion offset 1-3/4" to the pass side you'd need to cut 4" off but it sounds like that might get it spot on.
  11. 68 A
    68 A Well-Known Member
    563
    14
    Apr 16, 2006
    Auburn, NY
    Local Time:
    9:56 AM
    A neighbor got a rear for his 66 Barracuda from a second generation Dakota. I believe it bolted in pretty easily, but he had to get different rims with a much bigger offset to fit.
    Steve
    p.s. I bought a complete 8 3/4 with 3.91 suregrip (741) for $600, $200 to ship. Also had new brakes!
  12. pettybludart
    15,721
    120
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    8:56 AM
    I CALLED BUDDY BACK ABOUT THE DURANGO REAR.IT,S A 6 BOLT,SO IT,S OF NO USE TO ME..thanks for the advise..
