You move to Kentucky where they don’t careHow do you smog a 2005 Chrysler with an old 440 in it?
Do it!any one ever put a 440 in a new chrysler 300,
It really is great. The only “inspections” we have is if a car is bought out of state. And then the only thing they do is run the vin to verify it’s not stolen and check the odometer. When I bought my Scamp out of TN, I took it in to get it “inspected” with no exhaust, rotted out quarters and floor, nonexistent windshield wipers, etc. It was great!!Dang skippy.
Rip it all out and put the minimum wiring, gauges, switches back in.Next issue will be getting a "computerized" car to run with an old school motor. More sensors and re-mapping.
I found one on the local CL for 750 bucks. Bad starter and flywheel, probably a v6. Looks decent. You could take all the computer crap out and start over from scratch to get the lights, Windows, gauges, horn, whatever working and go. It would be an inexpensive (relatively) and fun project. No painting or rust repair or brake upgrades needed.thats right
no emissions inspection bs around here, they just check the vin if it’s from out of state.
the engines are basically the same size, it's just the electronics which a crank trigger kit, could be used to send crank position as a signal, cam sensor is actually made to read from the mechanical fuel position (company I won't name cause their customer service is stupid) as well coil pack conversion will help the mix as it may solve other electronic issues. There are already companies making intake manifolds for accepting the injector (if they sponsor me i'll name them) and a simple 90deg adapter will make the throttle body work. If I missed anything let me know as I am still mapping everything out.Next issue will be getting a "computerized" car to run with an old school motor. More sensors and re-mapping.
also to add ill be ripping a 6 speed manualthe engines are basically the same size, it's just the electronics which a crank trigger kit, could be used to send crank position as a signal, cam sensor is actually made to read from the mechanical fuel position (company I won't name cause their customer service is stupid) as well coil pack conversion will help the mix as it may solve other electronic issues. There are already companies making intake manifolds for accepting the injector (if they sponsor me i'll name them) and a simple 90deg adapter will make the throttle body work. If I missed anything let me know as I am still mapping everything out.
not needed ...Next issue will be getting a "computerized" car to run with an old school motor. More sensors and re-mapping.
I got one
