2006 charger console/cup holder in an A-body
Kent mosby
Idaho
My 1973 scamp needed a cup holder and I was looking and found one that might fit my bucket seats. It's a Mopar console. It looks like it belongs there in a restomod, not an original. Kind of expensive but it is solidly built. It squeezed in and I may not even bolt it down.
https://www.amazon.com/dp/B08J32Z1KW/?tag=fabo03-20
Thanks, I just put buckets in my 63 Belvedere 4 door.
That will fill the void perfect !!
I am unsure if I will use the sliding base provided. There is a nice mounting bracket set that I would have to remove seats to use.
25 inches total on the base. 20 inches on the console itself. 5 1/2 inches wide
Without the base it fits well. It is not leaning. Just the camera angle. The cup holder can also come out as seen in my first pics, it is loose
It is below the elbow as it sits right there without the base. You can slide it front to back about 5 inches total. With my shifter that puts it back past the front seats. This is where I will keep it. There are mounting brackets that connect to the transmission tunnel that may be able to raise it.
