2020 Small Block Penalty Box Race Sign Up
1971 Demon, 340-air gap-650 vac secondary Holley, 727-mvb-4500 stall, 8 3/4-3.23, headers, msd ecurve, drag radials.
15.9
gear 3.23 -.3
340 -.5
4 bbl -.4
headers -.6
.030 over -.4
727 +.3
converter -.7
mvb -.2
=13.0
Car runs 12.7s with a best of 12.53 in really good air last November.
15.9
gear 3.23 -.3
340 -.5
4 bbl -.4
headers -.6
.030 over -.4
727 +.3
converter -.7
mvb -.2
=13.0
I think you might have a deduction for your heads, unless you are running stock 318 2bbl heads. Nice run though...
I can play since the track opened..
1973 Dodge dart, all steel. weight around 3200 without my 350lb butt in it.
408 magnum block, trickflow heads, howards solid roller, super vic intake, qft brawler 950 carb, msd ignition, 1 7/8 headers, 3" exhaust, 4.30 gears, 255/60/15 MT Street R
Nominal time - 15.9
Weight - 3200 (-.1)
Gear - 4.30 (-.7)
Tires - 27 (0)
Elevation - 4000ft base (+.8)
Block - 360 Mag (-.9)
Carb/intake - yes (-.4)
Exhaust - Headers (-.4)
Heads - Aluminum (-.8)
Cam - Big (-.6)
Pistons - (-.4)
Crank - stroker (-.5)
Tranny - 904
Converter - 4800ish (-.7)
Valve body - Manual (-.2)
= 11.00
Run
11.509@118.67 - (DA at time of run 7,032ft I know it doesnt matter for the game)
Nominal time - 15.9
Weight - 3200 (-.1)
Gear - 4.30 (-.7)
Tires - 27 (0)
Cam - Big (-.6)
Pistons - (-.4)
Tranny - 904
= 11.00
Run
7,032ft.... Subtract a second..
our DA is always high with the heat/humidity. Our track is 600 ft, so I get noth'n. I don't count the DA either when I make my passes and post the ET slips on FABO. DA was about 3000 ft when I went 13.13 (remember we were in a rain delay in the video?), so you gonna give me my 12 second car ?? :poke: not until I post a 12 second slip, right? :D
600ft ain't 7,000...
Nominal time - 15.9
Weight - 3200 (-.1)
Gear - 4.30 (-.7)
Tires - 27 (0)
Cam - Big (-.6)
Pistons - (-.4)
Tranny - 904
= 11.00
Run
Didn't change anything but suspension tuning.
11.358@118.4
Well Dany hasn't made a successful run yet this year as we started out with some problems after the trans swap this winter (ended up being a bad "Orange Box") So her younger brother Nick and I jerry rigged a quick HEI swap onto it and He made an all time fastest ET for the car and an all time fastest top speed!! (and broke into the 13's so, helmets now)
And as an added bonus, he was able to take out the black mustang she fought all last year in Brackets at tonights Wednesday
Night Lights No Prep!
Enter him as Nick?
Its the same car Dany is entered with, should be a 12.2 car per the Penalty Box so we have a way to go yet but it's been a blast to see it go a little faster each time!!
To the gurus here, with a 100 MPH trap speed, where are we leaving the time on the table?
Any clues in the timeslip?
Thanx,
Motorpirate.
And as an added bonus, he was able to take out the black mustang she fought all last year in Brackets at tonights WednesdayView attachment 1715573534 Night Lights No Prep!
Enter him as Nick?
Thanx,
Motorpirate.
not that it has anything at all to do with your ET but that reaction time has a little to be desired...
Oh, it totally does!! But, those are his first real passes where the car didn't nose over and its only a green during Test and Tune, and arm drops during competition.
He will get it though!!
Enter him as Nick?
Thanx,
Motorpirate.
I looked at the Penalty Box again, and I must have not used all my toes and stuff before, because it came out 13.1 not 12.1, so we are a little closer than I thought!!
My car runs pretty close to ideal times from Wallace Racing
60' to 1/4 Mile Calculator - Wallace Racing
If you believe the HEI is up to speed now then it is time to start tuning the carb. If you can drive around the water box and back in you won't drag water from the front tires to the starting line.
So, I went in and added his #'s from the timeslip one at a time and it seems we are giving it all up at the 60' the 330' and 1/8th. or the bottom!! Above that we are going faster than the calculator.
Nick said the same thing about tuning, and I told him he needs to get to where he can lay down the same time repeatedly. Dany got to where she could hit 14.40's( with the old trans/converter) almost at will, and knew if she didn't,why.
I am sure a few more trips to just "run the car" and he will get it too.
And then....The tuning...
We started an 8.8 swap before the car started running like crap so now that it is back we hope to finish that and get some drag radials on it next!!
Awesome, making progress! Always exciting! 60 ft time is a little soft. I forget what gears.... and converter.... car should be fairly light... 360 magnum if i remember correctly.... but it looked like it hooked up good but are you mashing it out of the hole?. I can't really tell anything by the video. 21 mph gain in the last 1/8 is good for a mild small block, so the engine is making power for what it is.
Let me repost it.
'66 Barracuda
3600 lbs + .3 = 16.2
360 Mag -.9
4bbl -.4
headers -.4
Eq 318B's -.6
cam -.4
converter -.4
13.1
Crap, forgot the gears..
3.55 -.5 = 12.6
We definitely have some work to do, but that's the whole point, right?
I'm just sorry we had to waste 3 weeks fighting a failed component and not letting Nick learn how to drive the car.
But that's racing I guess!!
