215/70/15 on the front...67 and up Dart?
dusterdoug
Tracy, CA
Any real world experience? I haven't mounted mine up yet, but at 27-ish inches tall, they look like I'm going to have leading edge interference.
What say the FABO brain trust??
Thanks!
I used the 60 series tire, They do not hit anywhere. Just watch your back spacing.
Thanks!
What wheels do you plan on running? I've run 205/75s on my 68. With tall front tires, interference is as much dependent on backspacing of the rim as it is tire height.
I'm open to a wheel choice. I have 15 x 6 (3.75 bs) available but I'd think that's not enough bs.
Your 205's are almost an inch shorter than 215's. That 205 might be a better choice.
What wheels guys, will taller front tires are you running?
