245/60/15's or 235/70/15's
68 Coronet RT
68 GTS # 508 in Registry
Upstate New York
68 Dart GTS 340 automatic with shift kit few engine mods nothing crazy, performer rpm intake Hughes engine cam edelbrock 750 performer, stock exhaust manifolds 2 1/2 inch TTI pipes. Changed gears to 3:55 gears. Do I stay with the 245/60/15's which are very tight to my wheel lips or go with the 235/70/15's. I know the taller tires will effect my final gear ratio a little. Just looking for some opinions
235/60/15" is way more common, but might still be tight.
70-series tires are luxury car tires. Big and bulky. Looks 'crap' to me on small cars.
225/60 will probably fit better.
I'm pretty sure the 235-70-15 will hit the front of your wheelhouse-too tall in other words. On my 67 dart with 8 1/4, 15X7 wheels, 225-70-15, I have less than a 1/2 inch from the tire to the front of the wheel well. Measure 3 times buy once!
I did exactly that change on my 69 Swinger as the 245's rubbed on uneven surfaces. I put on 235 70 r15's and the issues went away. I do have an 1/8" spacer in front hanger for added clearance. The taller tire gives a slightly larger contact patch, also reduces final drive ratio which was welcome with my 408. I will look for my photos, both are posted somewhere on this site. Merry Christmas everyone!
235 70R15 on 8" wheel.
I mounted and balanced the 235/70/15's today. Put them on the car and have about 5/8 or a little more between the tire and the front of the wheel lip. I did pick up some more room between the top of the tire and the wheel lip especially on the driver side. With the 245/60's I couldn't get my little finger between the tire and wheel lip now I can actually get all my fingers between them.
