pishta
I know I'm right....
Balance no doubt. And I bet a buck that a 340 crank is lighter than a 273...
I would say that you've already saved $500 on the Block. If it was me I'd sell all all that crap and spent $1,400 on a complete stroker kit bearings Rings light rods the whole nine yards and have gobs of power beyond your World Imagine Nation. By the time the Machine Shop gets done buying Pistons refurbishing rods and grinding your Crank and adding the cost of bearings, Ten Bucks says you have had enough money to buy a stroker kit....
Is that a new band or something? Jk
Yeah, stroking it is always good....pffffft har har....But seriously, talk about a world of difference in power.
I will review the machine shop quote next week. We will be looking at the cost of the reman bill vs the stroker kit. Although my shop says you cant get a "good" 340 stroker kit for less than $1800 bucks. Do you have any personal experience with a budget stroker kit?I would say that you've already saved $500 on the Block. If it was me I'd sell all all that crap and spent $1,400 on a complete stroker kit bearings Rings light rods the whole nine yards and have gobs of power beyond your World Imagine Nation. By the time the Machine Shop gets done buying Pistons refurbishing rods and grinding your Crank and adding the cost of bearings, Ten Bucks says you have had enough money to buy a stroker kit...
But to answer your question I think all the stuff you using what you just fine.
What is you opinion on forged vs cast cranks in the stroker engine. I'm only building a weekend street car and funds are not without limits.Go to Summit and Jegs and look at stroker kits. They're all ship dropped from the manufacturer like scat. And even if you call Scott they will tell you that it's cheaper to buy it from Summit or Jegs then buy it from them because they buy in such quantity. Now I personally wanted 40 over Pistons for my stroker instead of the normal 30 over. So it took a few extra days.
Summit has The 9000 series cast crank, forged pistons and I-beam rods kit (1-98113BI) is $1523.97 and the same kit with forged crank is $1,985.97 (1-48033BI).
I will see what the machine shop quotes next week. If we get within $500 of the kit it a no Brainer.
340 crank had the throws drilled to offset the 129g heavier pistons and 32g heavier rods of the 340. 273 rods will hold up. Cast cranks are usually heavier than forged. When you got a "340 forged" crank from PAW it was a forged 318 poly or 273 that had its throws drilled and register resized.
instead of adding heavy $$ metal to the throws, remove metal from the crankpin side.
FYI my next build will not be a stroker. I'm not trying to jump on this stroker bandwagon because I have one. But again bang for buck...
I have 3 tons of Parts left over from stair step in my way to what I have. I want to restomod my 41 Studebaker with a Mopar drivetrain since I have so many parts available. That will be likely another year or two away.
YR- I left you a video on that unrecognized rock and roll band thread on the general discussion.
Why didn't you tell us you were in a band?
Hell, I'm impressed you can cover Metallica!
