Wedgy
Hi together,
I am building an engine for a friend.
It will be a 318 .03" over. I am having a nice looking forget crankshaft from a 1964 273 2bbl and will install it into the 318 block.
I will install Sealed Power cast pistons and don ´t know the correct weight for a nice ballance in combination with the 273 crank?
In the internet I could only find the weight for the 273 2bbl pistons only.
Can sombody tell me the piston weight including the weight for the piston pin, lock rings and piston rings?
Thanks - Wedgy
Thanks - Wedgy
