I do not know the brand unfortunately. That cam was installed when I purchased the engine. I have been told it is the same specs as a 340 cam. It ran really good with that, flattened out at around 5500 rpm. Will you use the domed pistons for compression?
I found my invoice, the springs I got was http://www.summitracing.com/parts/cca-26986-16 ...
Thanks for the number. I just got a set of those myself.
