3 SPEED WIPER QUESTION
WAYNE0
milton pa.
I know this question was probaly asked a million times. The wipers on my 67 barracuda stopped working. I would like to test the 3 speed wiper motor to see if its bad or if its the switch. Anyone know how to test them ?
Someone may be able to help, but it will be easier knowing what wiper motor and switch is on the car.
So far we have identified around 4 different motors used on '67, but none are three speed setups.
Look in the various service manuals, you can download them from MyMopar.com. some issues are different through the years and have more or less information. You may have to settle for Plymouth/ vs Dodse, as the site does not have both for all years
[/URL]
mmm ok interesting i didnt know that there was so many The motor on it looks to be the original. It looks like a 3 speed at least the ones im use to seeing. Ill have to take some pictures when my car comes back a front end alignment. The switch has 3 clicks. My dad had 2 67 GTXs and 1 had a 3 speed wiper motor & the other had a 2 speed. My looks like his 3 speed motor.
pictures of my wiper motor on my 67 barracuda its the same kind that was on my dads 67 gtx & his was a 3 speed
Can't help then.
It sure looks like a Leece-Neville
Never seen a 3 speed motor for a '67 A or B
Could the switch have been changed?
has anyone put a 68 and up 2 speed wiper motor in there 67 They are ALOT cheaper
What's the #'s stamped on wiper body? I have 67 3spd in our 67 cuda. I'll get a pic after coffee.
ill have to look unless someone switched them im very sure that my dads one 67 gtx had a 68 and up 2 speed wiper motor in it when he bought it
I dunno what you guys are looking at.
We've only identified one white plastic switch plate motor so far.
Some call it a variable speed and some call it a two speed.
The yellow wire goes from the motor to the white cover plate. Underneath is a switch.
There's three wires connecting to the bulkhead and wiper switch on the dash.
On the switch.
B is power in. B/U power to back up light switch. These two are connected to each other all the time.
With switch off.
Park is connected to Power (B)
When the power is shut off, the blue wire keeps it running until the switch on the motor's gear opens.
With switch in low.
The motor's Armature and Field both get full power from the switch.
With switch in high
The motor's Armature gets full power and Field gets power through the resistor.
So if this is correct then the test for the motor is to provide 12 to 14 volt power to both the brown and red wires. Then disconnect them and provide power to the blue wire to return it to park.
Above my pay grade Matt lol. I've always heard/read that 67 actually has 3 similar looking motors, 2 of which are 3/vs and 1 is actually a 2spd.
Again, hearsay but 4 wires is 2spd and 5 for 3/VS. Ours is 3/vs and has 5 wires.
On the switch.
With switch off.
With switch in low.
With switch in high
you know i was just thinking my wipers did work when i had the original gauge cluster in it I took out the original cluster & installed all new aftermarket gauges. I never put 2 & 2 together but thats when my wipers stopped working I wander if that has something to do with it not working. I also hooked my reverse lights up to a toggle switch
IIRC you posted '67 two motors and switches over in the wiper motor thread.
Nothing hearsay there. Just crowd sourced info and what we have found in the books.
On the switch.
With switch off.
With switch in low.
With switch in high
That is a Leece Neville wiper motor. I hesitate to say these are junk, but they certainly are not easy to find parts for. My 67 had one, I tried to rebuild it. Parts availability sucked. I got a prestolite V speed motor and linkages with crank arm out of a 67 A body at my boneyard, and scored the V speed wiper switch here on fabo in the interior parts sale section.
Do you remember how the power worked?
Am I correct that to test if the motor works both the Armature and Field need to be supplied with power?
(Grounding goes through the housing)
Damn dude, that was probably over 10 years ago since i rebuilt mine. I have slept since then lol
