302 head question
rustytoolss
Clinton, Ohio
Might sound like a dumb question/ but I need to know this. I'm going to swap out a pair of 675 open chamber heads, and replace them with a set of heart shaped 302 heads. Since I do not yet have the 302 heads. My question is....are the threaded holes on the section of the head closest to the water pump passenger side the same on the 675s and 302s for alternator mounting/ and the threaded hole down by the front lower cylinder head bolt.... better yet anyone got a picture of the front water pump edge view of the passenger side of a 302 head ??
They should be...I used all my original '67 brackets on my 302 install...no mods necessary. Sorry, I don't have a pic.
Hope this helps....
Casting #4323302
MERRY CHRISTMAS......
Rusty Tools,
Don't forget to get those #4323302 Heads 'Pressure Tested' ....before you have any work done to them........
Must be done with a 'Submerged Unit' like the 'AXE' unit below.
