JJH
Active Member
I don't follow.....?ow and ow
Check the 302's to be sure they are not cracked, usually visible between valves. If all is well, match roof and middle divider of intake only, sides and roof of exhaust only. Smooth transition in bowl, both intake and exhaust. Intake is suction, Exhaust is under pressure. Get a good valve job. Your engine should start within one revolution. Mill the heads .020 block side, .019 intake side. Use Felpro Head Gaskets and do not use steel shim intake gaskets. Don't swap gears. For your purpose they are perfect.
Details in post #25I don't follow.....?
Lol I hear ya now. Those numbers are really an eye opener! Thanks a lot!Details in post #25
Ow on the super tall tires with just 3.54s and
Ow on the 1600TC
No sweat,lol. My 2800 is circa 1980, with old technology. I actually worked at the place they were built and saw how the built it; it was real low tech. And I drove the crap out of it for many years and several cars with no transcooler.Lol I hear ya now. Those numbers are really an eye opener! Thanks a lot!
Now I'm in a predicament, that 2800 stall sounds real attractive but I do plan on occasionally towing later on; possibly for over 4 hours at highway speeds. How will the 2800 stall effect driveability? Even unloaded at highway speeds (2500rpm), it would have me revving much higher?
The 302's are still going to go on, I appreciate your opinion and understand completely, it's just something to occupy my idle time during school breaks while i'm home, like Christmas
That's a correction factor to a 1 ft radius so I can accurately say "X" amount of ftlbs to the road instead of into the rear axles; which is way less meaningful.And if you don't mind, could you clarify where the 24 came from when you did 24/30=0.8 please? I understand everything you've said besides that 24
Lol it's too bad Canada jumped the gun on switching. Being in college for MEng, I have to be proficient in both as well..... that's gonna take some workI'm Canadian too, but since I became a wrench before the government mandated and enforced the Metric crap system, and made me buy new tools, and I now have to measure the bolt-heads before every trip to the toolbox, I'm bi-lingual.
Thank you very much! So far I'm enjoying it. I wanted a career that I could work with my hands but still have the time and resources to feed my hobby lol. As we both know, vehicles aren't the cheapest to play withWhat year was that? Lets see, maybe 76/77/78-ish. So I've had over 40 years of wrenching pleasure, on he dual-systems. But very soon now, there won't be any non-metric stuff left,besides Harleys, and so the next generation won't have anything to complain about.
I wish you all the best in your career choice. If things had been different in 1972, I would have chosen that path too.
on your combo probably, most likely, I wanna agree 100%, but have to leave a lil room for...........How much you gotta spend on getting something else to bolt on.I personally think aluminum heads are a waste.
Called the engine shop today.... one of the 302's is cracked between the exhaust and intake valve. He is unsure; there is a possibility that they have a core sitting out back. He's going to check for me.
Anyway, if he doesn't, what should be my plan of attack? Pull the original heads, have them milled, can hardened exhaust seats be installed?, and a lil port and match work?
Or should I pick up some aluminum heads?
I personally think aluminum heads are a waste. My intake is 318 sized, my cam is small and I need torque. Larger ports and valves on aluminum heads will slow air velocity; therefore reducing low end torque and response. If you think differently, tell me. Still going to upgrade the converter either way.
Cam is all in by 4500rpm anyway lol. Intake range does not extend much further
Yes, hardened seats can be installed. Some just replace the valves with stainless and call it good. I talked with my machinist when I built my 273 and we didn't replace the seats or stainless valves. I only put a couple thousand miles a year on the car at the most. It will be a decades before there is an issue.I would look around, but most old vehicles are scrapped here. Not many survivors and the ones that do survive, are in use lol. I have yet to see a 273 around, and canada kept the Poly till 67 so that rules out 318s sadly lol. Are hardened exhaust seats something that can be installed? How costly?
