302 Heads on a 318 which hd gskts set?
dusty1
I have a stock 318 1972 model and have a set of 302 heads for it. Which complete gasket set would you recommend. Felpro or ? and any specific gasket set #?
While the Fel-Pro gaskets are very good materials, there head gasket surrplied in there kits are .039 thick and a bore of 4.1+ I think it is. Alittle thick and wide. But not a huge end all deal. These are the gaskets in the MP gasket kit now.
I have been reading some poeple have problems finding the MP OE head gasket. They are .028 compressed thickness. This is the one I would use with the combo.
IF you can find a head gasket closer to the diamentions of the 318's bore and as thinn as possible, that would be ideal.
Oddly enough, just posted a couple questions in regards to the '308' heads
the MP .028 gasket appears to be in stock at summit...
