318 A/C Delete - info
Saverio
nj
I have read through the many posts on deleting the A/C on my 318, 74 Scamp, w/power steering, cast iron water pump (i believe).
There seems to be conflicting information on what all i'd need. Some people say that using the the existing brackets/pulleys will work, just need the non a/c belts - others say I'd need new brackets/pulleys.
Which is correct?
I'd obviously like to do this on the cheap and I'm not worried about the engine looking "stock" - I just want the a/c GONE (i never, ever, use it).
something interesting, all the pulleys i've been able to find for crankshaft & water pump are only for the aluminum water pumps, not cast iron - leading me to believe all i would need is the non a/c alternator bracket.
1) Non A/C alternator bracket $37.50 - http://www.bpeusa.com/BPE5251.asp
2) Crankshaft Pulley $83.00 - http://www.bouchillonperformance.com/inc/sdetail/918/947
3) Water Pump Pulley $66.00 - http://www.bouchillonperformance.com/inc/sdetail/868/902
From what I can tell, it almost looks like if I use the alternator groove closest to the bumper, I might get away with not having to buy new pulleys & would just need a new belt?
Your water pump is aluminum. Easiest way IMO is remove AC compressor and fab a bracket for an idler pulley. Run one belt; crank, idler, alt.
Hell I'm thinking about ADDING (under dash knee knocker) AC to mine!!! LMAO
I have a non A/C water pump pulley I would be happy to trade you for some of your A/C hosing
Pulleys are a *****. There's never a way to piece them together unless you just get lucky.Best bet: find a non ac car or truck, with trucks being a better bet, rob all that crap at once. When I did my d150, I found a v6Dakota that had a nice idler and bracket and it freed up some power.
Next best bet: buy the pulley id book and hunt them down piece by piece.
