From Direct Connection Engine book: for every .010 off the chamber face of the head, or deck of the block, mill .0095 off the intake face. For each .010 off the deck of the block, .0144 is milled off the front and rear rails of the block.
You MAY be able to bypass the milling of the front and rear rails of the block.......DC gave this spec I beleave, so you could continue to use those stupid fat gaskets on the end rails, and don't bottom out your intake on the block before sealing up tight to the heads.......RTV on it's own works pretty good there. Trial assembly will tell the story....heads on with head gasket of choice, just snug, same with intake on with gaskets of choice, NO RTV in there yet, check gap of end rails with feeler gauge. I'd say if you've got more than .010 clearance between block and intake on the end rails, just bolt it together and let'er rip!!
Good luck!!
