txstang84
Well, if you can get away with a quick ball hone/bearings/rings/gaskets/krylon rebuild, groovy. The summit cam kit would work fine, and will be forgiving with the components-although I think you meant 901-16 springs...the 911s are drop ins for big blocks. I think you may be well served to advance the cam a few degrees though...I think it's supposed to go in at a 109*ICL...maybe bring it forward to 104-106* and if you can swing it, shave the heads a little with those thin gaskets.
Gears...well, if it's a 7.25" rear, I think you're pretty close to outta luck. The only places I see them with any regularity is on here...some guys parting out first gen Barracudas sometimes have some pieces parts for them...you try putting out a want ad for a set yet?
If you have the car for a few years, I might be interested
