The 600-650 cfm Eddy will occupy the space. Really need more info like compression ratio and cam for starters. If the car has an automatic tranny, definitely consider a carb with an air valve secondary (AVS, sometimes called a vacuum operated secondary). A smaller carb will give you better throttle response but will tend to restrict power output at the top end of the rev range.
