318 from a B-body to a Duster question
plymouthy
Livermore, CA
I just picked up a fresh 318 w/904 that was in a 1970 Charger, will it bolt into my 73 Duster that has a worn out 318?
Oil Pan and pickup?
Motor Mounts?
Transmission Mount?
Output Shaft?
Thanks
Pretty sure your 73 K member will have spool mounts instead of the older pedestal style. Thats about all the help I can give you. Welcome to the site though!
Everything should bolt right in if you use the Duster mounts. May have to shorten the driveshaft if the tailshaft on the transmission is longer. Hope this helps.
