318 LA cam question for the mopar gear heads!
okiemike
Active Member
walters Oklahoma
I'm fixing to pull the 318 out of my 69 notchback barracuda because the valve guides need replaced for sure. So while I got it out I want to do a complete check and replace any and all parts necessary. I will go back basically stock other than if it needs to be bored to 30 over etc. I plan on taking the head and block to my machine shop to have them vatted and checked etc. I will go back with a edlebrock intake and edlebrock 600cfm 4v carb. I have just installed dual exhaust. MY QUESTION is, should I go back with the stock cam, hydraulic; duration at .050 lobe lift; 192 exh.; 181 int.; 109 degrees lobe seperation or use a
Stage 1 high performance. May not be computer compatible. Use flat followers. .050" Duration-204/214; Cam Lift-.281/.296; Lobe Center-108/116.050) these are the two options that I was given by the parts book at my auto parts store. I appreciate any insight on this. All comments welcome. Thanks in advance!
I used a Herbert stage 2 on my 318 and was happy with it, all other things being stock, induction was from my commando 273 4bbl. good idle more power and top end.
Be prepared to get a lot of response to a simple camshaft question. As 70Duster mentioned there are many choices of cams for a mild 318. Probably the most common cam is the Comp 268H Part number 20-212-2. Here's a link:http://www.summitracing.com/parts/cca-20-212-2/overview/make/dodge
The reason it's so popular is that it makes good power, torque and doesn't require much for special valve springs, rockers, or pushrods. With a 4 barrell, intake, and headers or a nice dual exhaust you can have a fun 318 without breaking the bank.
The Summit 6900 is a great choice and very affordable.
I ran the Summit 1789 in my 318. It had an Edelbrock manifold a 625 AFB. and headers. It ran really nice.
Ted
The factory cam leaves a lot of power on the table any mild cam would be a huge improvement without sacrifice any bottom end. Comp xe262 or xe256 would also work.
IMO, while the Comp 268 is a great cam, it is too big for this application. I would look for something close to the old 204-214 @ .050 or there abouts.
If you're staying with the 'basically' all Stock Theory,
The Comp-Cams #260-H {#20-210-2} 'High Energy' profile is highly recommended
by the Cam Technical Advisors at Comp-Cams.
Especially for a light A-Body {1969 Barracuda Notchback} with a Shipping Weight of #2900 lbs.
* Lift ...................... .440"/.440"
* Duration................ 260*/260*
* Duration @ .050" ... 212*/212*
* Overlap ................. 40*
* LSA ...................... 110*
* Centerline ............. 106*
It is a 'Great' Camshaft for a basic 318, with a good Intake, mid-sized 4-Barrel and Dual-Exhaust System.
This Camshaft provides great Torque, and with a snappy Throttle-Response.
Though you're just doing a 'basic rebuild' on the 1969 318/230 HP, it would be beneficial to have the Machine Shop deck the Block to 'specifications' with the Flat-Top Pistons
@ -.029" below deck.
The 318 requires proper Compression {9.20-1} to gain power with a
'Low-to-Mid' Street Performance Camshaft.
Guys I really appreciate all the good info, I'm not a very good auto mechanic, but eager to learn. I'm a multicraft maintenance technician in a industrial plant and a electrician by trade. Thanks for all the good info and its great to be able to use this forum to pick your brains. Y'all got me to thinking that I may want to take it a little further on the rebuild!
