SniperDel
Hello, Im over on the B body forums but I figured I'd post up here as well. I found a weiand 177 for 1400$ new from a speed shop. The guys were gonna put it on a 408 sbc build but figured out it wasn't going to produce enough boost. I got the blower coming in today minus the belt, crank pulley and manifold. Im going to do a manifold adapter plate. Here's all I'm figuring that I will need.
650-750 carb (350$)
2-4" aluminum plate (intake manifold adapter, just gotta find it)
larger fuel line?
ARP Stud kit (150$)
belt (30$)
hei distributor (60-200$? Still not sure which make I should get)
2800 cfm electric fan with relay cut off kit (found one for 60$)
MSD boost timing control module (found for 140$)
Head/manifold gasket set (150$)
Crank Pulley (unsure how much or where to find on)
As far as I can figure doing a stock long block that's the basics that I will need for now. I personally want to get the transmission redone and I have a Mopar 8 3/4 with 4.10 posi's that I need to get bearings for and rebuild. Probably also need new studs for the axles as well. Any input is greatly appreciated. The big problem I'm having is finding a crank pulley. Would a chevy crank pulley be able to work in theory?
650-750 carb (350$)
larger fuel line?
ARP Stud kit (150$)
belt (30$)
