318 magnum distributer gear
mikec
hampton
I was working on magnum 318 on engine stand , turned motor over to work on oil pan, and distributer gear popped out, I finished oil pan , set distributer gear in and distributer, aligned distributer rotor to #1 cylinder tdc at timing marks on crank, Is this right or am I possibly off on timing, motor still on stand, just checking, my Clymer book (lol) doesn't show anything about it , thanks for any input,
As long as the #1 cylinder is at top dead, your good to go. Worst case issue, your 180*'s out when you try and start the engine. Then you just pick up the distributor, spin the rotor half way around and drop it back in. The engine will start.
watch the rockers as you move it back and forth past TDC. If they rock on #1 point it to #6 or vice versa.....
thanks everyone for the replies,i will give it another test tonight , valve covers are loose anyway, worst case it would be 180 out, that wouldn't be the first time, rer rer rer rer fooop, put the fire out , lol thanks guys
(1) pull plugs (for easier turning) (2) with 1&1/4" socket breaker bar turn crank bolt till timing slit on dampener is on TDC on the tab (3) move crank bolt back & forth a bit & see which rockers either #1's or #6's are moving (4) back crank slightly CCW till slit is at 15 BTDC (5) install/clock intergear anywhere (tho parallel with block CL is a good start) so that the dist tang can be dropped in anywhere as needed so rotor is (can be) pointing forward & slightly to pass side or rearward & slightly to dr side & if #1's were moving install tang so rotor is rearward/slightly to DR side, if #6's were moving install tang so rotor is forward & slightly to pass side then (6) turn housing so that (A) can is on pass side with room to be turned) and (B) magnet is dead even with a tooth (at this point the rotor should be under or very near under the cap terminal that is either forward/slightly to pass side or rearward/slightly to DR side. (this is rotor phasing/a seperate but important issue). (7) if the rotor is forward/pass side plug in #1 plug wire there & continue around CW 8-4-3-6-5-7-2. if the rotor is rearward/dr side then plug in #6 there & continue on around CW 5-7-2-1-8-4-3. gap at .008" with a brass gauge. You're almost ready to rock & roll. is this a new cam and or ring breakin? EDIT The can will alter rotor phasing & will shift the rotor CCW (on a SB) from its at rest position IE an 11 deg can will shift it 11 deg around the dist rim circumference
wow thats a lot of info ,i will have to read a few more times to understand it , but yes fresh 30 over motor 318 magnum new roller cam,thanks for the info
