318 marine engine.
Small Block Mopar Engine
  1. moparfan68
    moparfan68 Well-Known Member
    1,747
    80
    Dec 12, 2010
    virginia
    Local Time:
    8:13 AM
    I found a 318 marine engine complete from carb to oil pan. Still has trans or pump still attached to it. I can get it pretty cheap just wondering if it's worth getting ?is there any value or should I just leave it alone. Thanks in advance
  2. Garrett Ellison
    Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
    1,976
    1434
    Jan 1, 2018
    Southwest VA
    Local Time:
    8:13 AM
    What year is it? Some of these had a factory four barrel single plane iron intake that would make it worthwhile, and it might be a good way to get into a four lug mount block with thick cylinder walls and a steel crank. It would definitely be worth investigating closer.
    • Agree Agree x 1
    • jimjimjimmy
      jimjimjimmy lobsterman FABO Gold Member
      4,333
      1110
      Nov 2, 2010
      p. e. i.
      Local Time:
      9:13 AM
      There are standard rotation and reverse rotation versions. A reverse rotation would not be great for a vehicle .
      • Agree Agree x 5
      • RustyRatRod
        RustyRatRod 30 Degrees Outta Whack FABO Gold Member
        57,294
        26718
        Jun 7, 2010
        Georgia
        Local Time:
        8:13 AM
        Most single engine boats had reverse rotation engines. If it came off a dual engine boat, it could be a clockwise rotation engine. I would get it either way. A crank kit is all it will take to remedy that....and of course whatever camshaft you want. Some of them had unusual gear drives for the camshaft, but once removed, the blocks are the same as far as bolt on accessories. I have never heard anything about them being thicker, but that's certainly plausible, since marine engines and parts are more heavy duty than their automotive counterparts.
        • Like Like x 2
        • Wyrmrider
          Wyrmrider Well-Known Member
          2,218
          1065
          Sep 5, 2016
          los angeles
          Local Time:
          5:13 AM
          obviously check for rust
          and check block- if run cold in salt water they can be full of salt crust
          both standard and reverse cams are still available
          you might be able to flip it to the boat crowd
          good motor
        • MOPAROFFICIAL
          MOPAROFFICIAL Well-Known Member
          4,552
          3531
          Jun 1, 2016
          Between a tit and an armpit
          Local Time:
          5:13 AM
          The cranks rear seal surface will have diverter grooves in the wrong direction because it is reverse rotation ...so in a car, standard rotation...it may piss oil out the rear main.
          The thing I'd look for are the water cross over style head, they're closed chamber. Last digits are 234 of the casting number.
          • Like Like x 3
          • toolmanmike
            toolmanmike FABO Staff Staff Member FABO Gold Member
            44,798
            28528
            Jan 18, 2006
            Iowa
            Local Time:
            7:13 AM
            A 318? They are quite easy to come by. I would'nt mess with a marine teen.
            • Like Like x 1
            • Agree Agree x 1
            • MOPAROFFICIAL
              4,552
              3531
              Jun 1, 2016
              Local Time:
              5:13 AM
              Especially if you're over the age of 18...
              :D
              • Thanks! Thanks! x 2
              • Agree Agree x 2
              • Dana67Dart
                Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
                3,097
                1694
                Jul 16, 2017
                Northern Colorado
                Local Time:
                6:13 AM
                Slightly off topic but I have a question...
                67 318 vs 67 273 vs 69 318..
                am I correct that the 67 318 and the 69 318 do not have interchangeable parts like a 67 273 and a 69 318 more or less do. ( hope this makes sense)
              • RustyRatRod
                57,294
                26718
                Jun 7, 2010
                Georgia
                Local Time:
                8:13 AM
                BWHAHAHAHAHAHA!
                • Like Like x 1
                • AJ/FormS
                  AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
                  17,062
                  5603
                  Jan 19, 2014
                  South-Central Manitoba,Canada, 900ftelevation
                  Local Time:
                  7:13 AM
                  IDK but the pistons will be bore specific,lol.
                  Cranks are piston specific,
                  And pop-up pistons do not play well with closed chamber heads.
                  Early models had lightweight rods, while smog era teens used 340 type rods but with pressed pins..
                  Otherwise from 67 on,almost anything goes.
                  The 69 318 was a high-compression 9.something engine; 9.4 I think.
                  If you are building a performance engine, it doesn't really matter, cuz you are gonna be replacing almost everything anyway. And if doing a stock rebuild, from a core, it still doesn't matter.
                  The only fly in the ointment is the early 273 heads (65 and older) with the small odd-angle intake-bolts.
                  That's all I know.
                  • Agree Agree x 2
                  • Thanks! Thanks! x 1
                  • moparfan68
                    1,747
                    80
                    Dec 12, 2010
                    virginia
                    Local Time:
                    8:13 AM
                    It's a 72 block it's a 4bbl with a carter carb still on it. I can get it for 100 to 150 for whole motor but I didn't k ow if it would be worth it or should I just let it get crushed. I'm goin back in the morning to get some parts off a mid 80s w250 truck that was brought in. When I was lookin at the w250 a guy workin in there stopped to talk to me and said if I like mopar stuff I should look at this "big block 442 they had" I said hech yeah I've never seen one before. Lol. it ended up being a 318 marine motor.
                    • Like Like x 2
                    • moparfan68
                      1,747
                      80
                      Dec 12, 2010
                      virginia
                      Local Time:
                      8:13 AM
                      The 234 heads can they be used in a car or just marine application. Do they have any value ?
                    • Daves69
                      Daves69 FABO Gold Member FABO Gold Member
                      4,504
                      2586
                      Feb 20, 2011
                      WestOfChi
                      Local Time:
                      7:13 AM
                      Does it have the ID plate on it?
                      • Like Like x 2
                      • MOPAROFFICIAL
                        4,552
                        3531
                        Jun 1, 2016
                        Local Time:
                        5:13 AM
                        You can use them in a car, but I recommend you block the water/heat cross over though.
                        Use .019-.021 thick steel and copper rtv.
                        Otherwise water will flow through the manifold. Some who have egr ,its a must or your motor will eat coolant... but non egr is no worries. But the trick is too plug them, pipe plug on the block side would be nice.
                        The exhaust ports are blind due to the water heated deal and so they all flow even with no end gas passed around to the other bank...which is why they're the most desirable 318 closed chamber head imo.
                        • Like Like x 1
                        • halifaxhops
                          halifaxhops It's going to get stupid around here! FABO Gold Member
                          55,486
                          23289
                          Jan 20, 2014
                          CENTRURAL, PA
                          Local Time:
                          8:13 AM
                          I run a 440 that was reverse rotation, just need the oil pan and cam and distributor only. And you have to polish the crank seal areas also.
                          • Agree Agree x 1
                          • toolmanmike
                            44,798
                            28528
                            Jan 18, 2006
                            Iowa
                            Local Time:
                            7:13 AM
                            How many 318's do you want for $100-$150? Why pay the price to toss away a lot of marine pieces you can't use. (unless you're building a boat)
                            • Like Like x 1
                            • Agree Agree x 1
                            • moparfan68
                              1,747
                              80
                              Dec 12, 2010
                              virginia
                              Local Time:
                              8:13 AM
                              If the marine motors or there parts had any value I would buy it if not i will just let it set.
                            • jas0162
                              jas0162 Well-Known Member
                              466
                              276
                              Apr 23, 2014
                              kansas
                              Local Time:
                              7:13 AM
                              I run an industrial 318 in my daily driver, it had very low miles so I changed the pan and water pump housing and threw it in the dart. It has the water crossover heads and they are great, seems to keep the carb an even temperature even on the hottest days.
                              • Like Like x 2
                              • moparfan68
                                1,747
                                80
                                Dec 12, 2010
                                virginia
                                Local Time:
                                8:13 AM
                                • Like Like x 1
                                • Daves69
                                  4,504
                                  2586
                                  Feb 20, 2011
                                  WestOfChi
                                  Local Time:
                                  7:13 AM
                                  Specs are same for '73...…….
                                  • Like Like x 1
                                  • halifaxhops
                                    55,486
                                    23289
                                    Jan 20, 2014
                                    CENTRURAL, PA
                                    Local Time:
                                    8:13 AM
                                    Look on e bay for the parts value think I sold the cast oil pan over 200 and a revers distrib is 100 easily. Exhaust manifolds are big money also on them.
                                    • Like Like x 2
                                    • moparfan68
                                      1,747
                                      80
                                      Dec 12, 2010
                                      virginia
                                      Local Time:
                                      8:13 AM
                                      Once I got to scrap yard and looked it over it was obvious it had sit for awhile lots of rust. The exhaust manifolds looked like they had froze and cracked. I pulled distributor and a few parts and left the rest.i got quite a few parts off 88 w250 too while I was there.
                                      • Like Like x 1
                                      • moparfan68
                                        1,747
                                        80
                                        Dec 12, 2010
                                        virginia
                                        Local Time:
                                        8:13 AM
                                        Would you be interested in these Distributors?
