But most guys are gonna use 3.23s with an automatic, cuz now you can cruise 65=2600/zeroslip.
So now, 60 in second is 3800@zeroslip, say 4200@10% slip. You can still use that 4300rpm cam, but you'd be giving up 300 to 400 rpm at the top, and of course, it's more cam than you need for fuel-economy.
But a cam with a 4200 power peak is already pretty small, being a stock smogger-teen cam. So what do you do? Well if stuck with a 318, then you are gonna need some stall to get moving. And more stall if you wanna be quick. But a better solution is just to get a bigger engine.
In a 3600pound car, do you need a 360/5.9?.... that depends;
A 360 with 3.23s and a 2800stall will just annihilate the tires in first gear. A 2000 stall and a 318 cam in that 5.9, will still annihilate the tires in first gear.
The stock LA318 with bolt-ons has about the right amount of power at low rpm with about a 2800stall and 3.23s. It just doesn't have enough in second gear, to really be fun. It's not bad in a straight line...... but second gear, IMO, is just too soft.
So it kindof depends on what your goals are.
By choosing a 360/5.9, you got all the bases covered ...... I mean you don't have to floor it every time you take off,lol. And it has great! second-gear power, lol, especially the 5.9, in stock for stock comparison.
IMO a hi-compression 340 with a 318/360 type cam, and nice heads would be just right. And since I already built such a combo, and that 340combo is my second-favorite all-time build, I can say that,lol. I called it my big-bore teener.
