I was thinking of changing the intake on my daily driver 87 Ramcharger. It is completely stock except dual exhaust. What I have is the stock LB carb already on it. Starts/runs/drives great. I also have a stock 360-2bbl intake and carb. Cast iron 360 spreadbore intake and a 650 Holley carb. I also have an Eddy sp2p intake and a 600 Holley square bore carb.
I personally am thinking of using the 360-2bbl combo that way i wouldnt have to worry much about linkage and still retain the choke. As i said it is driven to/from work (80mi/dy). The current intake has an oil leak by the dist, so it needs to be pulled to reseal the intake. Hopefully I covered everything.Thanks for the suggestions!
