subscribed
Through the 1/2 ohm resistor.Mattax,
Looking at post #12, how does the 4 pin ECU get power during cranking [ start ]?
Is that just hte ECU or ECU with coil?OK from what I have tesed at adle most draw 4 amps and running around 2 amps. They do noy like any voltage less that 10VDC
When I pull the vacuum advance engine diesPull the vacuum advance and set timing without it, maybe it's on the wrong port...
If the dist has done a lot of miles AND the vac adv is hooked up [ & working ], the p/up wires may have finally broken from constant flexing. Disconnect plug & while wiggling the wires, check resistance. Should be 150-600 ohms & STEADY.
Other possibilities: plugged fuel filter, sock in the fuel tank blocked with debris.
