318 Stuff + Blower
jeremiah2146fa
Grayland
Rating - 0%
0   0   0
Lots of Small Block Block Mopar Parts
$300 8-71 blower off of an 8-71 diesel.
No serious pitting, NO bearing play. A quick spin by hand and you can feel the air blowing.
You'll need a manifold, carb plate and drive setup, but if you're brave enough to try fabbing, you can make some CRAZY horse power for cheap!
$75 318 Forged crankshaft
$500 302 casting Swirl Port closed chamber 318 heads fitted with 1.94-1.60 valves so no cylinder notching is required, 20 miles on rebuild (bottom end died)
http://www.hotrod.com/howto/113_0304_318_small_block_build/index.html
$75 like new condition camshaft with complete Gear drive setup (also have lifters which have been carefully kept in order)
Will seperate the gear drive and sell it by it's self for $50
Purple Shaft Cam
Adv. Duration: .268°/272°
Dur. @ .050'': 228°/231°
Lift: .450''/.455''
Centerline: 110°
Basic RPM: 1500-5800 RPM
$75 1967-74 318 block bored .040 over
$15 1974 Carter Mechanical Fuel pump
$25 1974 Power steering Pump
Complete set of brackets -make offer
1967-74 318 heads 9600 miles on rebuild (have old smooth cracks between exhaust ports but no leaking they were rebuilt with the cracks) -make offer
1974 360 factory 2bbl manifold -make offer
1974 360 factory 2bbl carb -make offer
the green heads are the swirl ports
Curious, would these heads (the 302s) drop onto my 273 with no notching and would my adj valve train go right on including the push rods I have now?
The gear drive is in the pic with the cam I'll look for a manufacturer/ part number, the heads have 1.94 valves, not the 2.02's so you should be good.
old, I am out of the running ... feel free.
I think Im next in line for the gear drive (sent PM 5/19) , Have not heard boo from this guy, IM or Email. If your out there, check your PM's or send me one! Pishta.
I've still got LOTS of good stuff. Make me an offer!!! I'm looking for a 360 rebuild kit right now, so I'm open to trades!!!
Make me an Offer!!! I need some capital so I can keep working on my car! I have tons of stuff!!!
I can't believe that NO ONE is interested in the BLOWERS!!! This is hot rodding at it's purist! All the origional drag cars were running these detriot blowers. Their cheap, and make HUGE power!!!
Hey:
What's the casting number on the 2 barrel 360 intake? Got any pics of it?
Thanks!
Steve
