My understanding was that some 318 truck engines had better crankshafts, forged instead of cast and were desired for use in building hi proformance engines.
Sorry to hijack but I have a similar question...
Im thinking of pulling the 360 outta my 84 Dodge 1/2 ton and.putting a 318 in for better mileage.... any obstacles other than sump and oil pan? My ac works and would like to use it with the 318
Thanks!
The important thing to remember, and it goes along with this thread, is that 318/340 oil pans cannot interchange with 360 oil pans as the 360 pan has a larger diameter opening at the front and rear of the pan.
You will need a 318 truck pan to go along with the 318.
Will all the externals be able to swap from my 360 to 318? Ac, ex manifolds??
Thanks Dave!
I believe this to be true, and as the 318 has the same stroke and bearing sizes as a 340, is a 318 forged crank the same as a 340 forged crank? I have often wondered if they are the same part....
I believe so. You are also going to have a converter balance issue. You'll need to knock the big weights off the 360 converter. Frankly, I think you might be heading in the wrong direction. A good running 360 can get fair mileage, and that truck is heavy. The money you spend on a swap will take a long time to pay the difference in fuel.
