318 vs 360 mounts?
What's the difference between 318 and 360 engine mounts?
The mounting ear where the mount bolts to the block on one side is about half an inch narrower on a 360 bs the 318. The other side is the exact same as a 318. I forget which side it is off top of my head I want to say the drivers side
Yep, drivers side.
Fortunately the way the mount goes on the ears of the block (in front of them front and back) that 1/2 can be made up with a spacer.
IIRC there is one bolt hole on the drivers side that doesn't line up at all.
The lower rear one I think.
If you go to the "Magnum swap" section and look at my thread. "My 5.9 into 68 Dart swap". Scroll through till you find the part about how I modified my drivers side 318 mount to work on the 5.9 (360). It might give you some ideas. You can buy a 360 mount if you can find one, or buy the aftermarket swap brackets, but its much cheaper to modify your existing mount.
