Im glad i stumbled on this too!. I recently took out a 71 318. I wasnt sure if i should rebuild it or go with something else.HUMMMMMMMMMMMMM:read2:
This is the way I see it.
The only modern muscle car...which doesn't make the grade of muscle, but gets the nod my millions as a great platform to build up a nasty street car on, is...ugh! The Mustang.
For years, this pony has been powered by the 302. IF they can run quick on a 5.o, then why can't you on a 5.2?
Lets look at the Ford power plant a second.
Tiny 3 inch stroke, 4 inch bore.
MoPars 318 has a 3.31 stroke which is more and means more torque and a 3.91 bore, which can be bored out bigger. How far you can safely go is just a sonic check away.
Hensley performance takes selected 318 to punch out to 4 inchs. HELLLO!
Typical overbores are done at .020, .030, .060 while Hensley has found a few every now and again that will take .090. YIKES, not really recomended, but do able.
At .020 it's 321 (3.93)
@ 030 it's 323, (3.94)
@ 060 it's 328 (3.97)
@ a 4.00 inch bore 333 cubic inchs.
Pistons are the cave eat for this size engine.
OH, if the Ford guys get cute and threaten you with a 347 stroker, then perhaps one day, you'll play ruff too with a 318 stroker that displaces 390 cubes. At a .030 overbore.
LOL, ha ha ha ha sit on there head and fart! Loudly!!! :toothy10:
Better heads, abilty of stouter cams due to the larger lifter, great intakes! Vic Edelbrock even sez so!
