[SOLD] 340/360 externally balanced flywheel
The 340 and 360 cast crank flywheels are different in balancing pionts and the material needed to be removed,but can be done from a stock neutral balanced flywheel,mrmopartech
the mopar performance oval track modifications manual has a diagram to do the balance work,If i find mine I will try to scan and post pic's
Going to have one machined...Special thanks to FABO member 684mulas ...Dave is a great guy!
