ir3333
Who have used a stock 318 converter behind a 340 ?
What were your cam specs and what was the stall speed ?
Why would you use a 318/904 convertor behind your 340?.
Sorry dont have the specs,I pulled the 727 out of a 68 340 cuda,all factory,had a 904 that had been rebuilt also had a new convertor for the 904,put it in made a few changes but it still works great.Other than it has more room and different shift points it works great.it all depends on the cam in the 340, and gears. if it works why not run it?
Low stall probably 1400-1500 on a guess. When we rebuilt converters we never (as an industry) never really persued their stall speed as it wasn't necessary. You phoned in and asked for a converter for a specific transmission and engine combination and you got the converter required. High stalls were a different game, lots of questions to the customer that needed to be taken care of before any high stall even sold.
One thing that I'd like to mention, your chances of getting a NEW CONVERTER for anything other than a NEW car are two, slim and none, they don't make them for older cars, there's no reason to.
Do you mean they're phasing out converter manufacturing for older 727's, 904's, T350's, etc, etc.??? Are the only ones you can buy from Summit, TCS, etc rebuilt ones?
I have a stock 68 318 904 converter behind my mild build 360 and it is brake stalling at 2100 rpm. Mine didn't have anything marked low stall on it.
I was hoping for 25-2600 as a factory "high stall" should have given, but as it stands, even with 2.76 gears my car is already traction limited. Once I get the 3.25s in should be awesome for a street car. My 360 is set up for good low rpm torque.
