I run this cam in my 340...if you are looking for some old school thinking. My compression ratio is around 9.6
Brand:
Crane Cams
Manufacturer's Part Number:
691191
Part Type:
Camshafts
Product Line:
Crane Mechanical Flat Tappet Camshafts
Summit Racing Part Number:
CRN-691191
UPC:021174013634
Cam Style: Mechanical flat tappet
Basic Operating RPM Range: 3,000-6,500
Intake Duration at 050 inch Lift: 238
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 238 int./248 exh.
Advertised Intake Duration: 300
Advertised Exhaust Duration: 310
Advertised Duration: 300 int./310 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.500 in.
Valve Lift with Factory Rocker Arm Ratio: 0.480 int./0.500 exh.
Lobe Separation (degrees): 114
