[SOLD] 340 engines (7 of them)
jeff_mopar
Member
So Cal
Rating - 0%
0   0   0
I have several 340 blocks for sale, if you buy a block I will offer you a crank, rods, heads, intake, etc. for extra $.
'67 block standard bore. Date 10/2/67. $1,500
'68 block fresh .020. Date 9/11/68. Vin. # LS23P9E133254 $1,300
'69 block. .020. Date 8/11/69. No Vin. # stamped (warranty block) $1,500
'70 block. fresh .055. Date 3/5/70. Partial Vin. # 1B152915 $700
'70 block. .030 Date 7/1/70. No Vin. # stamped (warranty block) $1,500
'70 block. Standard. Date 9/23/70. Partial Vin. # 1B324930 $1,500
Completely Rebuilt 340 never assembled or run.
I had this engine rebuilt for my car and then changed directions on it. Best of everything done to it. '73 block(no Vin. # stamped), .030 over. .010/.010 forged steel crank, micro polished and radiused oil holes, ARP rod bolts, resized big ends, new full floater bushings, new KB Pistons, balanced, Mopar Performance cam and lifters(multiple to choose from), rings, bearings, oil pump, roller timing chain and gears, etc., rebuilt 2.02 J Heads with Comp stainless valves, springs and retainers. I have everything for this engine new in the boxes. Plus all of the other pieces to make it whole like oil pan, valve covers, intake, carburetor, timing cover, bolts, etc. Just needs assembled. I have all the receipts for everything. Asking $6,000.
Located in Southern CA.
Thanks for looking!
Jeff
