I don't know what Edelbrock recommends. Where did you see that? All I recommend is RTV around the water passages only, on all the bolt threads and the china walls.So edelbrock recommends putting gasket sealant along the whole intake mating surface? Is it really needed since its just sealing for air? I mean i understand putting rtv or gasket sealant around the 4 water passages, i guess having it on the whole intake mating surface cant hurt right
I will say this. Normally, @missing linc is 150% right. Gaskets and RTV don't go together most times, but IMO, gaskets sealing around water passages can be an exception. Sometimes, RTV can act as a lubricant and cause the gasket to squirm out from under the parts being torqued together and cause a leak. Since the intake gaskets have many bolts going through them, that's not possible, so I always use RTV around water passages only on the intake gaskets.
