Need advice for 340 intake swap
Doesn't an 87 model have an ECM and TBI?
Close- TBI started in '88, trucks only. Cars used an electronic feedback carb with the gen 2 electronic controller.
Looks like it may have a standard electronic ignition..?
OP, is there an ignition control box on the inner fender somewhere? Looks like this:
I put a 4bbl 750 vac sec carb and intake on my 273, it had a 2 bbl. It was faster with the 2bbl. I wouldn't go over 600 cfm.
I was expecting holes on a 3462848 intake to look more like this one (not mine):
The one he posted looks like the primaries have been opened up to me.
Maybe it's the lighting or my eyes are shot (that's possible). Also, the primaries on his manifold look irregular to me.
No you’re definitely right. Looking at them in person you can clearly tell.
There are a few variations. Throw in the TQ intakes and there are several variations.
That's a '68/'69 manifold (3/4" bypass fitting).
So what will I have to do with all the wiring to be able to make the 340 intake work?? I know probably take most of it out but how and then what. Will I need a new distributor?
The port mismatch is much ado about nothing. Ma Mopar herself build millions of 318 engines right from the factory with big port intake manifolds atop "mismatched" small port heads, so they must notta thought too much of it.
As I've covered before, you end up with column of air the size of the port, drawing thru intake with occasional gains in torque, proven by Mercruiser on various engines, most obviously w/Square Port Manifold on Peanut Port BB Chevy heads(a huge easily seen difference and probably the easiest to search for details on). & heard some Ford engines, that I never heard details on,
And step on bottom of port 'mismatches' is best(least objectionable), as in a turn fluids go to the outside of turn & inside of turn is slow(think about boating on a river)
And step on bottom of port 'mismatches' is best as in turn fluids go to outside of turn & inside of turn is slow(think about boating on a river)
Exactly. In other words.....it can have some positive effects. Besides all that, the engine is only going to pull in what it needs. It's not like air and fuel is gonna "pile up" at the intake port at the head. That ain't how it works.
If it runs and drives nice I personally wouldn't bother changing the intake.
I always tell people not to mess with daily drivers. They ususally end up a mess and then you'll wish you hadn't touched it.
Now, if you were going to do other things to increase performance maybe, but I would just leave it stock at this point.
Tom
I have an 86 Mustang gt convertible other than maintenance I dont do anything to it its stock. Its a driver. fun too :)
