340 manifolds..
abodyjoe
Berlin,N.J. 08009
saw these while ay oc md this past weekend and figured i'd post the pics...
look to be the good manifolds..
Are you sure those are the 68-70 right side manifold? It looks like the 71+ to me (at least when I blew the picture up to get a better look).
thanks fro posting this. what is the going rate for a set of these? i had a set years back, but sold or traded them...i don't remember.
either way i need a set and prices i see are way high.
thats bonkers, i am hoping to have the whole car put together for less than that!
has anyone tried other manifolds in an early A with 360? the later 340 manifolds look basically the same as the 68-70, so where are the fitment issues??
Usually in the $350-$400 for a good used set. They do reproduce them too for $600 a pair or something like that.
The '71 and up 340 pass side manifold has a center outlet and is more restrictive.
400 is about right. Check out the Dakota logs, they say they fit but I have yet to see it. Supposed to flow as good or better. There are 2 sizes, the early ones are larger, and dirt cheap too.
wish i could find it mopar muscle or one of the magazines did a flow test and the magnum exhaust manifolds flow just as good as the ol' hi-po manifolds EXCEPT there is steering (power) shaft clearance problems...the engine has to be raised a bit. Amazing how far technology has come in 35+ years magnum manifolds are by the billions while those dang hi-po 340 manifolds are like gold, even 20 years ago!
so i have been watching ebay and various forums, seems a decent set of 340 HP manifolds is going for about $450 .... new ones are available from shakerhood.com for $550
but are the e body HP manifolds the same as the a body HP?
Nope, they are the early mannyfolds. The later ones have a horizontal rib that runs the length of the passenger mannyfold that that one clearly does not have.
