You can buy new inserts, but the quality is not very good. Neither is the fit. I have found that the material used in today's motor mounts is worse than terrible. We replaced the engine side mount in my son's 87 Daytona. Within six months it had collasped bad enough for the k-member to be able to tear a hold in a CV boot.
The replacement spool mounts are usually a loose fit in the original brackets and require a couple of tack welds to hole them in place. They are made in places like India and Korea. I have not found any in years made here like I have suspension bushings, which appear to be made with much better rubber.
