Installing the B3 Racing geometry correcting rocker setup on my 340. Shims are needed to get the .015 - .030 clearances between pairs of rockers. Anyone know of a valve spring shim that will work on the .875 shaft without grinding the ID? The largest shim ID I've found is .785.
