Speedmaster Stainless Rocker Arm Issues
And every aftermarket head as well, but we know this.
Has someone checked out the Trick Flow heads for this? They seem better in every other aspect, you'd think they would have improved the rocker shaft location, too.
I will try to be more clear or complete.
The Speedmaster heads are basically copies of Edelbrock LA heads. The rocker shaft stands are in the same location as the Edelbrock heads.
The Speedmaster stainless rocker arms are basicaly copies of the Comp Cams stainless rocker arms. I have both sets, measured them for comparison, and they are dimensionally the same.
The retainer contacting the rocker arm happens on Edelbrock heads with Comp rocker arms too. So this is NOT specific to Speedmaster parts.
The reason previous posts said to correct the geometry first using a kit from B3 racing is because the rocker shaft stand positions the rocker shaft too close to the valves and too low FOR A ROLLER ROCKER ARM. That is usually the only cause of the interference. So if you get the measurements from B3 Racing website and call Mike with that info he can make the kit properly. It is not just shims. It is usually an offset shim to move the rocker shaft up and away from the valves a specific amount based on your measurements. Some are considerable. Once kit is installed you can double check for the interference. Usually there will be plenty of clearance there with the kit installed, no rocker arm grinding, no beehive springs and no small retainers.
The Trick Flow heads moved the rocker shaft position. That is why guys with Trick Flow heads are not reporting all the clearance issues. They require much less correction.
Lastly, once you install the correction kit you will likely have to add clearance for the pushrods in the cylinder head.
Sorry for the long post. Just trying to be clear and cover it all in one spot.
Please don't apologize for the long post, this ends the thread and actually answers the question I was asking instead of talking in circles about how rocker geometry is affected by multiple things lol. This is exactly the information I was looking for, all in one post. I was under the impression that the Speedmaster stuff was a copy of the Edelbrock stuff, but was not aware of the rockers.
Since I don't have access to the website, I will have to find Mike's email, since I don't usually find time to call. I will go from there. Thank you!
According to Mike- B3 - IIRC - for the TT heads the Harlandsharps need no correction and the PRW could use a minor one just to dead nuts on.
B3 Racing Engines LLC
PH: 717.497.6572
Email: contact@b3racingengines.com
Alt Email: b3racingengines@comcast.net
Business Hours (EST):
Monday through Friday, 8:00am to 5:00pm
Saturday, by Appointment
Here are some other threads.
Post 20 in this one shows Edelbrock heads with PRW stainless rockers and same retainer interference:
Correcting Mopar Valvetrain Geometry
Post 34 in this one shows how one of the measurements is taken for this kit, then in post 43 you can see how thick and how offset this particular combo needed the spacers (spacers visible under shaft):
Valve train geometry
This thread shows pushrod interference in post 1 and clearance added in post 19:
Pushrod Rub (Intake side of head)
I didn't think it was talking in circles at all. In fact, there's some great information being shared from members who seem to care about a job being done correctly. I know I for one can easily stop doing any of that on your threads in the future, if that's what you'd rather.
No, I did not have to do anything to B3's partial correction kit. The trick flow heads have some corrections engineered in. Valve stem wear or contact marks are spot on with the partial correction kit.
I thought I had read elsewhere the Trick Flows were better about geometry.
Haven't read all the posts.
Comment:
- the rocker geometry can be correct...& still have rocker to retainer contact. More likely with the SBM because the rocker is so short.
- use beehive or conical springs! Problem solved.
Comment:
I mentioned that and got dissed. It's a fix.
Mike is in the process of finalizing my 340/416 Stroker build- can’t wait, should have it back this week fingers crossed!
Regarding heads- I had originally gone with SM using the 1.6 Hughes rockers before I contact Mike to do the build. I had him do a correction kit, still had to grind the inside of the Hughes rockers to clear SM valve springs that came with them.
Since Mike had had the motor and soing
The build, had nothing but issues with the SM heads and luckily he had a set of Trickflow 190’s. It only needed a very rocker shaft small correction for the 1.6 Hughes rockers- running hyd roller cam custom ground based on his specs, can’t recall but def not more .530 I think.
I rambled here but my point is- I wish listened to all the guys on here that said “GO TRICKFLOW” with the money I thought I’d saved going SM I ended paying more for port work and rework and ended up still not using them. Seems like some guys get lucky with SM but that wasn’t me.
That is incorrect, Rob. The Harland Sharp rockers need more correction than most, even on the TF heads. Throw a set of T&D 8130 rockers on a TF head, and run .700" net lift, and you won't need any correction. Outside of that scenario, it will need adjustment, just not as extreme as other "factory copy" type heads.
To address other comments as well, the factory engineers did very well at the stock rocker geometry. Once us performance nuts start putting aftermarket parts on the motor, things get sideways in a hurry. Has anyone ever seen a factory motor with roller rockers and say, .550" lift"? No? Well, that's why the issues start when we do it to our engines.
Oh crud! Thanks for popping in for the correction.
Excellent update. So if I can remember that down the road….
Instead of screwing up the info …..
But that’s why I also tagged you. This is what you do and I do not. Obviously I’m a hobbiest. Not a professional.
I have to call you up for help on a project.
We again will be speaking shortly.
You didn't get dissed, Mike. You don't know if clearance will be an issue until you know the shaft is at the right place. Then you can rightfully determine whether the beehive springs need to be used. I call that being informed. There was no disrespect given, at least not from me.
Comment:
Yes it can. But again, if you don't know whether the shaft is at the right place, you don't know for certain why there isn't enough clearance. If the geometry is truly correct, not just centered on the valve tip, and you still have clearance issues, by all means, use a different spring if that fixes the issue. FWIW, I haven't had to grind on a rocker for over 15 years, and I rarely run a beehive spring.
On the madhatta360 motor, I did go with a smaller spring (not beehive) because even with the geometry correct, his was one of the rare occasions that there was still a minor clearance issue. It rarely happens, yet you hear about this issue all the time and the rocker gets blamed. Fix the geometry and the odds are that you solve the clearance issue as well.
SBM alum heads. 241 @ 050 hft cam; 0.589" valve lift.
Beehive springs, stable to 7000 rpm.
What am I doing wrong??? Got new H&S full roller arms. I have already reduced the thickness of the shims from the ones supplied by H&S to about half the size. I had a solid .015-.020 clearance. But when I tighten the rocker shaft down with the push rods installed every thing tightens up and I lose the clearance. I tried positioning the hold down blocks. It worked great. It has the proper clearance but tighten it down with the push rods installed it all goes tight. These are on Eddy RPM heads.
Are the rockers hitting the retainers?
Are the adjusters hitting the pushrods and forcing the rocker over?
Most of the time when your scenario pops up the rockers are hitting the retainers.
And before the bullshit starts flying, a beehive spring is NOT a fix.
If they are hitting, a lash cap is NOT a fix.
If they are hitting the fix is to call Mike at B3 racing engines and have him hook you up with a geometry correction kit. That is THE fix.
Sorry, forgetting and/or late to the party updates…..
What size springs and retainers are being used?
I just checked them out. Yes, the rocker and the spring on the underside of the rocker has a very small amount of interference between the two parts. I will try and shim the rocker shaft. I have the shims they are .005 in thickness. The old rockers were H&S form Mancini but did not have a roller fulcrum. These old rockers were showing wear on the bottom of the rocker (the anodizing was worn away to bare aluminum) fulcrum and had also wore a pattern into the old rocker shafts that you could physically see and feel on some of them. And I had the heads shaved .005 to remove the marks from the steel ringed head gasket. That why I bought the rocker shaft shims. But, I did not install the shims because they basically closed the oil passage to the heads. So I will waller out the holes in the shims at the oil feed holes and use a little super glue just enough to hold them in place when bolted down to promote proper oil passage around the two oil feed passage bolts. Thank You for your response.
It looks like the Speedmaster rockers on their site are bushed. To the OP, if they are not bushed, be careful. Inspect the shafts for ant galling or wear on a regular basis. Hard stainless rocker and hard shaft don’t make the best couple.
One important thing I learned from Mike@B3 is the SIZE of the sweep, not just the position. He got my PRW's to around .035 sweep jut a hair off center.
If ya read the whole 3 or 4 page article, you see that "dwell' is key.
Been dealing with him for years. The Jedi Knight of rocker to valve function.
So you’re saying it took approximately a $3000.00 set of Trick Flows to fix approximately a $500.00valve spring and retainer fix? Or a let’s say a $1000.00 rocker arm change. Or am I not understanding something? Or missing something? Kim
