More or less what I did. Started with a Hughes fast-rate 223/230, 11.2Scr,and double O/D. 1.97 final drive.
Later a Hughes fast-rate 230 went in. And I gave up the double O/D, trading away the 833od box for a 3.09/direct 4th box, but keeping the GV,and still with 3.55s.
Takes off like 4.10s, cruises like 2.77s.
I have 2 carbs; a fat 750DP for hammertime, and a lean 600Vsec. for touring.
The fast-rates are small on the advertised, making Dcr easy to get, and rhoads optional.My cam sounds very tame, compared to other combos with smaller cams, yet pulled 93 in the 1/8, the very first successful run. I am no longer concerned with gas mileage, but with the 600 tuned lean, it's still pretty good.Our Canadian gallons are bigger than yours, tho. So if I told you I was getting 30mpg, you might have a heart attack, or chalk me up as a liar. But on good days it does high teens US, and occasionally breaks into the 20sUS. Course I can lean that 600 out to get much better numbers, for straight hiway use.Which I have occasionally done. The 223 cam easily broke into the 30s US.But then it was idling down the road with a 1.97 final drive.
As a side note, that Chrysler 292/509 drank gas,bigtime. I didn't run it very long.
