[WANTED] 35781R Hub for 10" drums
AlaskaJeff
Palmer, Alaska
I'm looking for a 10" v8 sbp front wheel hub for my Duster. The splines have left the chat.... I would take both sides if you have the pair.
Do they come in bbp for the same drums? If so that would work better.
From a low mile 67 Barracuda Commando. Drivers side still has the left hand studs installed. You can have everything(2 drums 2 hubs) for $100 shipped to you.
'65-72 A-body with 10" drum brakes. All were small bolt pattern (4" bolt circle). The only way to go to the 4 1/2" bolt circle is to change everything from the spindles out....unless you use some funky wheel adaptors....
Thanks for the offer. As I am in Alaska, shipping alone would be more than $100,so I am sure the price would be more. And I don't really need the drums. Thanks anyway.
Not looking to make money, but I didn’t see you are in Alaska. I’ll do the two hubs shipped for $100 if you want them.
