360/5.9 stock cam specs
thanks for posting that
it's a missing link in my records
awfully wimpy cam for that displacement, and awful close to the stock 318 flat tappet specs.
there's some debate on the LA roller cam being the same as the flat tappet.
love to have that resolved and the reasoning
my suspicions are that it's the same lift but the ramp is faster gaining "under the curve".
I can post some comparisons later tonight exactly what are you looking for YY1?
post your records whatever you have
YYY1 here are some entries from my database sorted by seat duration at SAE or .004
Some Part numbers may be big block but not to find the SBM equivalent HR marked HR some lifts are at cam some at valve easy to see which
lift duration .004 .050 Timing
351/351 no adv given ` 181/192 109 LCA Sealed Power CS-645 273-318 stock
.274/.278 251/271 188/194 -22 30 23 -9 116/107 111.5lca E-1807-S ELGIN E-PNs sealed Power 645 gives icl 110 excl 108 LCA 109
.375/.375 240/240 188/188 114 LCA Cam Dynamics 1500 240H14 1000-3000 1500-2000 cruz
392/390 192/192 Cam Dynamics 15202 383 4bbl 315 Hp 2268405 big block
400/427 248/260 192/204 112LCA Crane 693971 H-248-2 HMV-248-2-NC
265/.280 260/270 194/204 8 22 27 13 45 105/115 110lca E 983P
.405/.405 248/248 200/200 112LCA Cam Dynamics 15001 248H12
368/398 250/260 184/194 110LCA 105 ICL-115EXCL WG-1183
.387/.403 253/266 184/193 MC 1309 HR 94---Melling
410 (273) 278 (59) 203 -7 30 32 -9 109 LCA 108 ICL 111 excl Elgin E-626-S ED s-645
TRW-TM 627
.410 /411 .273/.274 no adv 197/199 111 LCA 114 108 2806283 Wolverine CS 4115 marine
.427 260 204 110LCA 260H10 Cam dynamics 15003
398/420 (265/280 ) 260/270 (45ovlp) 194/204 8 22 37 13 110 LCA 105 ICL 115 excl Elgin -983P WG 1184
427/454 260/272 204/216 112 LCA Crane 693901 1,500-4,500 H-260-2 HMV-260-2-NC
372/400 264/274(50) 180/192 -20 21 24 -12 114 LCA 110 ICL 108 EXCL Elgin 577S Engine Dynamics S-645
248/266 at cam
.372/.399 264/275 12 72 57 38 (50) 180/192 -20 20 24 -12 109 LCA 110 icl 108 excl Melling SPD 20
.458 (.305 lobe) 264@.004 202 @.050 120@200 Mike Jones Special any ex and LCA
.440 266 210 110LCA Cam Dynamics 266H10
459/480 268/272 212/220 112 LCA Crane (some crane shelf grinds are .904- check
459 268 212 127@200 57 intensity Crane .904 H3 race only .200 duration for intake lobe
398 270/259 205/196 MC1262 HR 92-93 Melling
420/420 270/270 204 110LCA 106 icl 115 excl WG 1105
420/420 270/270 204/204 4 28 36 12 110LCA 106 ICL Edelbrock 2177 16” vac idle -5500
420/443 270/280 204/214 112LCA 107 icl 117excl WG 1116K 204-214 cam
.410/.425 203/208 -5 28 38 -10 -14.5 (.050) 106/114 110 lca Oregon Cams #1006 (RT) 1.5 rocker
.259 271/271 191/191 -20 31 20 -19 115/115 115LCA E 861s HR
.303 272/272 216/216 3-33 43 -7 52 105/1115 110 lca E1789P at cam
454 272 216 110LCA Cam Dynamic 15005 s 272 H10
455 272 (52) 216 3 34 33 4 110LCA 105 ICL 115 excl Elgin 1789P at valve no idea why timing changes different catalog
454 272 216@050 110LCA SUM-1789 largest stock engine cam works best with 9:1 and gears 1,500-5200
454/454 272/272 216/216 110LCA 1,800-5200 Crane 272H10
454/480 272/284 216/218 112LCA Crane 2000-5000 H-272-2-NC “Max Velocity”
385 /401 274/264 13-80 61-23 37 ovlp 108 ICL 112excl 110 LCA P5249663- hyd roller 360/300 crate motor mech fuel pump
431 274 202 114 @200 H2 H-202/2880
480 276 220 136 61 Crane .903 H3 H-220/320 note difference .903 makes
451 unknown duration 205/209 209 lca Delta #836-203-2 regrind
.294 276/288 218/228 0-38 53 -5 54 109/119 114 lca E-1223P
441 276/288 (54) 218/228 0 38 53 -5 109 LCA 109 ICL 119 excl Elgin 1223P
441 276/288 218/288 114LCA 1,800-5500 Summit 6901
480 276 220 136 70 *4 H3 CRANE .904 lobe
.270 276/271 197/195 15 32 32 17 62 113/113 114LCA E 1722-S HR
.294 276/288 218/228 0 38 53 -5 54 109/110 113lca E1223P
.273 278/278 203/203 -7 30 32 -9 59 108/111 109.5lca E 626s
420 (.280) 278/278 (50) 204/204 106/114 110 lca Edelbrock Perf Plus Sealed Power CS-1006R 1500-4000
.273/.274 278/282 198 199 -15 33 27 -8 57 117/108 111 lca E-1578s 273 Hyd cam
421/444 278/288 204/214 112LCA 1,200-5000 SUM 6900
421/444 (.281/.296) 278/288 (59) 204/214 -6 30 43 -9 (-15)112LCA 108 ICL 116 excl Elgin 937P SP-CS 1089R 1500-4000
420/443 (270/280 adv)? 204/214 112LCA 107 icl 443 excl WG 1116 adv may be at different height)
420/443 278/288 27 71 76 32 204/214 5 29 44 10 112lca 107 in 117 excl Melling MTD-1
.281/.296 278/288 204/214 -6 30 43 -9 59 108/116 112l ca #937P Melling MTD-1 Summit 6900 421/444 w 1.5 “1200-5000”
467/494 278/290 222/234@.050 114LCA 2,200-5,200 Crane H278-2 and HMV-278-2-NC
.286/296 279/290 210/221 -13 43 40 1 51 118/110 114 E-1579S 340 & 360 Marine retarded
.429/.444 .286/.296 279/289 209/220 -8 37 46 -6 50 112/116 114LCA #578S ELGIN CAM Melling SPD-22
429/444 (286/296 279/289 .004 (50 ovlp)210/220 -8 37 46 -6 (-14) @.050 114 LCA 112 ICL 116 excl E-578-S` S644 SP-CS-644 Melling SPD-22
429/444 .2861/2958 279/290 (50)trw TM578 Sealed Power CS-644 2899206 340 CAM 1500-4500
429/444 286/.296 210/220 114 LCA 110-118 Wolverine CS 4109 marine (LH available)
429/444 {268-276 MOPAR DEGREES } 210/220 WG 1118 oem #4214671 275hp 340
429/444 210/221 Crane 963901 276hp 340 114lca Cam dynamics 15002 220-221 H14 Crane blueprint
421 (.280) 280 (58) 208 -3 31 39 -11 (-14) 111 LCA 107 ICL 115 excl Elgin E-938-P SP cs 1006R 1500-4000
443 (295) 280 ( 60 ) 214 1 33 41 7 110 LCA 106 114 Elgin E-1087P WG 5023
460/450 280/288 224/232 112LCA HIT-280-2-HIT CRANE
443/465 280/290 214/224 112LCA 107 in 117 excl WG 1161
480/480 284/284 228/228 112 LCA 284 H12 Crane 3000-6200
480 284 228 112LCA Cam Dynamics 284 H12 2800-5800
.305 284 /284 218/218 4-34—44- 6 65 105/115 110lca E-1042P
.320 284/284 228/228 7-41 51 -3 61 107/117 112lca E 1798P
.320 287/287 231/231 8-43 46-5 69 108/111 109 lca E 935p
.444/466 288/298 (61ovlp) 214/224 -1 35 48 -4 69 108/116 112lca E-936P M23203 highly recommended by some 20 degrees more duration than a MOPAR cam and less lift- go figure Sealed Power CS-1019R 2200-5200
.501/.513 288/292 P4876348 360/380 crate HR 1.6 rockers
Thanks, interested to hear your opinion on advancing that cam a few degrees.
Which cam Montclaire
Slant64 is going to degree his Oregon regrind
cam starting today
we will also report on Where Oregon was able to fit the "RT" profile on his stock HR lobe
The stock 360 TBI cam. I know those motors had a reputation of over scavenging the exhaust charge.
stock tbi cam
the one with the shorter exhaust
couple of degrees would not hurt but you can bet the factory has lots of R&d on that application
you need more low end?
running stock exhaust?
Running stock 340/360 pass car log manifolds and factory duals. Otherwise stock 1989 360 with a mopar electronic ignition and edelbrock 318/360 performer intake. Trans is a 727 (1973 with part throttle kick down and transgo 2) with a CR20 converter (about 2400-2600 stall behind a 360). Gears will probably be 3.55s, don’t want to go much higher than that. Curb weight I’m probably 500lbs lighter than the B250 van and 1500lbs lighter than the D250 that it would have come in so maybe I’m overthinking it. Motor is rated at 190 hp/292 torque. It’s not a performance build but no reason to leave any on the table.
I would not change it
with a new timing chain +2 is ok
you do not leave anything on the table all you do is move it around some
get some miles on it before making changes
your motor is basically the same as
slantsix64 's
but he's putting a RT like regrind
I'm going to move that LA cam list to the 318 sticky page
