HotLines
Realist - Free Thinker
Follow me here, I have a 1991 Dodge P/U with a 360 TBI engine and 518 transmission. The truck has 40,000 miles and runs excellent. This next week I will be pulling the engine and trans right down to the ECU and ridding myself of the body. I want to install this engine and trans into my 64 Signet which originally had a 273 V8 then a 340 w/ a Dynamic 727 pushbutton trans.
What exactly will I need to install this completely stock 360 and 518 O/D into my 64 Valiant Signet with a minimum of problems. I do not want to run a carburetor or use the 727 trans which is in the 64 at the moment. Believe me I have more then enough 340 engines, race parts and heads to make most all Mopar enthusiasts jump for joy but I do not want to use anything other then this stock engine and trans setup for my 64 Signet. Will I need motor mounts from the P/U which Ill have and will I need any kind of extra wiring for the TBI to work in the 64.
Mind you as I do have a plasma cutter and enough tools to accomplish whatever is needed but I do not want to cut my 64 anymore then needed or turn this into a quagmeyer as just want this car on the road and drivable.
Can you help me?
Can you help me?
