[SOLD] 360 block with crank
duster360
Alabama
I have a 360 block with crank for sale. The block has a fresh .020" overbore and new cam bearing installed. The crank has been turned and polished also, crank was balanced and has the B&M flexplate that it was balanced with but I no longer have the harmonic balanced. It also has ARP main studs in it. I put the shortblock together to go drag racing and changed my mind. So I pulled the cam, rods and pistons out it and sold them. I do have a set of connecting rods that can go with the engine for no extra cost if you want them. I have no use for this engine anymore so it needs to go. Local pickup only due to size and weight. Asking $200.
I will post pics later today.
